Problems with NX/Open CAD/CAM development.
andradrr
Automotive
Oct 26, 2010
7
Hi people!
Please, I developed a NX/Open function that automaticaly sets the spindle speed and the feed rates for the selected CAM operation, based on the tool name for that operation.
Everything works ok but I would like to be able to call this function with the operation oppened, I mean, while you are editing the operation parameters/values.
The problem is that, when you call a user function, the operation dialog closes and the values that you have modified are not commited (saved).
So, my question is: Is there any way to run a user function and then resume the previous dialog from the point where you called the function, or at least commit the changes before the dialog closes?
Thanks a lot for any help/idea.
Cheers,
Rodrigo.
Using the Speeds and Feeds library you can assign values to a library tool. When that tool is used the Speeds and feeds are assigned, there is a manufacturing preference to make it automatic.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
