MedicineEng
Industrial
Dear All:
I am facing a big issue regarding one heat exchanger that I have installed in my plant. Let me just give you some insight about the system:
This is a monofluid system (secondary system) that has 3 different tanks (and respective HE and pumps) at different temperatures.
The one that is in negative temperatures is the one that is giving me a lot of problems due to the low thermal transfer.
One side has brine at -22/-24C and in the other has the fluid that will will cooled and pumped to Production areas.
The problem is as I already said the low temperature transfer across the HE. These were the actions that we already performed with reduced/minimum improvement:
-Cleaning of the HE in both sides;
-Checking of the brine modulating valve (it is operating fine with no restriction);
-Checking of pumps (Ok);
-Checking of brine pumps (Ok, since I don't have complaints about any other area fed by the pumps)
The brine system is able to withstand the thermal needs since the brine temperature is always in the range.
When we are in heavy production the temperature can only go down around 2C ( from -13 to -15C approx)that means a difference of at least 7/8C to the brine side.
Am I missing something?
Thanks for the help.
