I'm working with a rather complex XLA application that
previously had no problems involving EnableEvents when run
in Office 97/2000. In Office XP it does crash however.
Application.EnableEvents is set to False while a
subroutine populates the rows of a sheet with data stored
in memory. Concurrently, a userform displays a progress
bar. Previously, while the sheet was being populated, the user was able to click and highlight cells, or switch between sheets in the active workbook.
On XP, however, do so results in the following error:
"Run-time error '50290': Method 'EnableEvents' of
object '_Application' failed."
Are there any known problems with EnableEvents in XP that
cause it to behave differently than in previous versions?
