Problems importing data
toyayo
Automotive
CA
Has anybody ever run into this error?
Import not possible for 1 reason ....
"Existing item inaccessible" .
I am trying to import a drawing into my TDM, previous lower version of the drawing used to be in the TDM but was deleted. This new drawing has a higher version, so I am not sure why it would not import.
Do you know how the original drawing was deleted?
ie. via I-DEAS or at OS level
RCDLtd,
I removed the previous version thru manage libraries, because I thought that it was creating the problem. I still do have a copy in a separate folder.
I also noticed that in the import error, under the 'additional info" colunm that the 'project/library' info is missing for the drawing but not for the other data. I checked the 80 character max. rule and my path is well below that.
I talked to UGS and they think I should run
DMADMIN - DIAG - CH on the project. I will post the results.
