Problem with the reaction forces in a 3-point bending model
T.Gmai
ES
Hi everyone,
I am modelling a 3 point bending test on a SENB specimen with a fatigue precrack using Abaqus/standard. For the FEM model I've used 3D solid to model the specimen and discrete rigid body to model the punch and roller, as for the crack I've used contour integral. I applied a displacement in the RP of the punch.
I need the load-displacement curve from the model but when I compared the results to the experimental test I have obtained higher reaction forces, 2 times higher . I tried to refine the mesh but it didn't work also I've checked my material, it's fine.
I have two different steels, the results of one material are good, I have this problem only with the second material.
any suggestion on how or where could be the problem?
Thank you in advance
Are both models exactly the same, apart from material data ? It would be best to copy one of them and then change only the material constants to make sure that there are no accidental differences between these models.
The geometry is exactly the same, the only difference is the crack length. I tried to change the material in one of the model with the closes crack length that I need but still have the same issue. one of the material is highly ductile, the other is more brittle I am afraid that the model is not capturing well the material behavior.
Which material model do you use ? Linear elastic or another one ?
Elastic-plastic for both, to capture the plastic behavior I used true stress strain curve from the tensile test.
