Problem with static analysis for composite beam
fariz838
6
Hi everyone,
I'm having problem when modeling composite beam with concrete slab with static analysis. This analysis involve with the composite beam and concrete slab were exposed to fires. I keep getting this error 'THE MATERIAL OPTIONS *CAP PLASTICITY, *CAST IRON PLASTICITY, *CLAY PLASTICITY, *CONCRETE, *CONCRETE DAMAGED PLASTICITY, *DRUCKER PRAGER, *FOAM, *CRUSHABLE FOAM, *MOHR COULOMB, *JOINTED MATERIAL AND *PLASTIC ARE MUTUALLY EXCLUSIVE'. Can someone help me to solve this problem?
I has define material properties of elastic, density, drucker prager yield criterion including hardening and also concrete damaged plasticity in which I specify plasticity, compressive behavior and tensile behavior. I really appreciate if someone could help me.
Thanks again
I think the message is pretty clear: You've used plasticity options, that can't be used together.
