Problem with saving & opening files from network.
Wicsteve
109
Last week we updated our computers to use Windows XP. Our Solid Edge files are stored on a network drive running under Windows 2000. Since the update we are having difficulty retrieving and opening the Solid Edge files from our network. Previously, when I was running Windows 2000 on my workstation, I had no problem.
Symptoms: 1) After initially turning on my workstation and logging on, I can open any file (par, asm, dft,etc) without difficulty. If I close the file, and then try to re-open it, there is a very long delay before it opens. Close the file again, then try to reopen the file for a third time, an error message comes up saying the file is in use and that it can't be edited or saved. 2) If I store the file on my local drive, I have no problems in saving or retrieving the file. 3) If I open the network stored file only from Microsoft's 'Explorer' window, and not from within Solid Edge then there are no problems. 4) We tried running Solid Edge in a Window's 2000 mode (simulation through Windows XP) and problem remained. No other program is giving us any problems with file retrieval. 5) After the problem occurs, I can restart my computer which resets the file to read-write,and I can again edit and save the file. The problem however starts all over again.
Anybody else have any similar problems and if so, how were you able to resolve it?
Yes i have some error messages as wel, network errors, lanmanredirectors faults when saving.
BUt answering to ur number 2)
make the filename as simple as u can for testing like:
a.asm or what the filename for u is
i had that once that some symbols were not allowed on network but do work on local drive
