Charoenpon555
Hi everyone,
thank you for you kindly support
I have studied a steel plate 140x240x10mm which subjected to load 1153 N. This plate is constrained with six bolts. I calculated the stress manually with Stress = force/Area got about 1MPa (average). and I also try to calculate by FEM with Patran. I created model with 2 conditions of load , Load on edge and load on surface. I expected that average stress generating on plate would be the same or nearly each other. But the result showed that with case that load on edge the average stress on plate is about 10 times (at least) higher than load on surface (It should be the same except only stress concentration region I think). Could anyone guide me what cause this problem?
Sorry for my English,
Thank in advance for helping
Charoenpon555
Charoenpon555
