I can't get AutoCAD to keep the number of command lines visible. I can set it in options to 3, but when I close CAD and restart it always returns to a size of 1.
I start CAD using "C:\Program Files\AutoCAD 2000i\acad.exe" /p "c:\Rebis201\AutoPLANT_PDS.arg"
I have edited the profile in the registry and set the key CmdVisLines to 3 but CAD always opens with 1 line. When I go back and check the registry the key CmdVisLines is set back at 1. (I have administrative privledges on this machine)
I have edited the AutoPLANT_PDS.arg file as well.
Funny thing is, everything worked fine for several months. We recently started using the Batch Plot Utility that ships with AutoCAD. I can't prove it, but I believe that this utility may of created this problem. I noticed the problem shortly after using this utility for the first time.
Any suggestions will be greatly appreciated.
Thanks.
Thanks.
