mahdizamani
Hi there
Recently I've been modeling a piezoelectric layer attached to a base beam by ansys.I want to study the effects of frequency on the electromechanical behavior of beam and piezoelectric layer.Now I have some problems doing the analysis:
-I defined contact between the base beam and piezoelectric layer. As you know contact makes the analysis nonlinear and for harmonic analysis nonlinear behaviors are neglected. The software will solve the problem without nonlinearity and it may lead to inaccuracy.The harmonic analysis is the only analys type available for studding the effect of frequency change on the behavior of structures.
-Piezoelectric analysis needs an electrical circuit. For defining the circuit the ansys help suggests using CIRCU94 element .But first I need to define electrodes and I don’t know how to do that .By using electrodes I can estimate the total voltage and electrical current produced by the piezoelectric layer.
I will be pleased to know about your suggestions.
Thank you
Thank you
