Z
Zippy38
Guest
All my users have the config.pro setting load_ui_customization_run_dir set to yes.
I have 3 out of 10 users, with the same problem, on different hardware. All 10 users are on Creo 2.0 M060. 3 users cannot load the company *.ui file. I have one user where the file was loading properly till yesterday and the laptop crashed. After the crash the .ui file would not load.
When loading the company .ui file manually, it still does not work.
If the problem users customize their own .ui file, this file does load, but they cannot share the company .ui file.
Any help will be appreciated.
b.t.w. I found that although the config.win file is no longer edited in Creo 2, if the config.win is not in the Pro/E working directory, most of the icons are smiley faces!
Wali
Wali
