I have to import in Solidworks some DXF files I generated with another program (GRASP, a software for antenna design). The drawings represents some mirror dishes.
When I try to File->Open->DXF I get the following message:
__________
'<file name>' is possibly an AutoSolid model.
It contains 3D faces which may not import properly. Import this file without the 3D faces?
__________
If I answer No, the import windows quit. If I answer Yes, the process goes ahead. At this point I select:
- Import to Part
- All selected layers
- Import this sheet as 3D curves
(I don't think the other parameters are relevant).
I can clearly see the facets in the model. But when I press on "Finish", what I get is just a blue polygonal line representing the perimeter of the mirrors, but not the rest of the lines or the points (the perimeter is represented as a series of "ImportedCurves").
Do you know any way to prevent this problem? I know this is possibly a problem with the software generating the dxf, but I can't find out any solution on that side.
Say happens with
Any help appreciated. Thanks in advance.
p
__________
__________
- Import to Part
Say happens with
p
