Problem filtering negative values of a matrix using loop statements
erloroloco
GB
Having a matrix defined by one column with 4000 integer values in rows, I would like to convert the negative ones into 0.
e.g.
v=[0;-1;-2;4;..]
vconvert=[0;0;0;4]
Therefore I tried to use the example described in the Mathcad13 tutorial, which skips over the nonpositive numbers with a "continue statement".I don't get a solution. Other procedures like "if statements" are also helpless for this "rookie" beginner.
I would be really delighted if someone could help me with an elegant solution.
Thanks a lot.
If you want to do it without programming, one way is:
(v + abs(v))/2
2 notes: One, make sure to vectorize the equation (matrix toolbar). Two, make sure to use the absolute value from the calculator toolbar, not the matrix toolbar (which is actually the determinate).
Peter
Already answered in Mathcad Collab. Problem was trying to modify a range variable.
TTFN
