Roy,
If your looking for associativity between the solids (as in one body drives the distance between/size/shape of the others), I think EWH was on target with grouping the body and arraying the group. This allows you to have an array of seperate solids in the file, all associated to the initial solid. To accomplish this;
- Application Modeling/model nav, highlight body so that the body is higlighted in the list
- Right click (3rd button, whatever), click 'group', follow the bouncing ball. I'd recommend hiding the features, but to each his own (keeps the model tree cleaner and if a downstream user tries to edit, the 'group' feature comes up which should clue them in...
I think this approach is worth looking into.
Shadowspawn
The early bird gets the worm,
But the 2nd mouse gets the cheese!
