S
samfisher
Guest
I am trying to assemble support frame for a parabolic trough. The main support frames are of the required parabolic shape and so is the sheet (note that in pro/e the sheet is modeled as a standard part, not a sheet).
The problem is I can't get any constraints to fix the sheet on to the frames. The sheet has to be bolted on to the frames and I have provided the required holes. I moved the sheet and placed it on the frame and then applied the fix constraint. This is not a satisfying method of constraining.
Please help me in this regard. Hopefully the image attached will make my question clear.
