Pro program
  • Thread starter Thread starter karthik23
  • Start date Start date
K
karthik23
Guest
Can any sort of link be given between variables from one program to another.
i.e if a dimension is calculated using some relations in a program, the value assigned to the dimension (after computation) should be used in some other programs.
If all that is written in context on single assembly then you can do that in ProProgram.
