G
guliba
Guest
When i did a simulation of drop/impact using pro/mechanica motion, something wrong were happened. The problem were:
1.The highlight contact surfaces contain planner surfaces. Since plane-plane contact i snot supported,no contact pair will be created between planer surfaces.
2.A pair of surfaces in contact region 'contact 1' are interperetrating too deeply for accuate geometry calculations at time...check surface geometry and initial conditions for possible problems.
3.Pro/mechanica detected contact at the edge of a surface in contact region 'contact 1' at time...currently, pro/mechanica does not support edge contact.
Anyone can tell me the reasons. Thanks a lot!
