Pro/Mechanica Units For Stress
  • Thread starter Thread starter UnclePinchPenny
  • Start date Start date
U
UnclePinchPenny
Guest
When I do an analysis for stress on a part it gives numbers but no units. What are the units if in (mmNs)?
mmNs stands for MKS units.
mm-millimetres
N-Newton (MKS unit for force)
s-second
This should make it clear:
The MKS unit of force, the newton, is the force which accelerates a mass of one kilogram at the rate of one meter per second per second.
Check this link:
http://instruct1.cit.cornell.edu/courses/virtual_lab/popups/unitConv.html
The units of stress in the mmNs system are N/mm2 (millimeters squared) which is also Megapascals (MPa). 1 N/mm2 = 1 MPa. Therefore in your results, you may have numbers for stress like 5e+02. This is 500 MPa.
