pro manufacturing
  • Thread starter Thread starter m_ammar_t
  • Start date Start date
M
m_ammar_t
Guest
Hello everybody:
i have been trying to use pro manufacturing to simulate a process of real manufactring but i faced many problems so can you please help me .?
Hi m_ammar_t,
by the way, ghareeb98 is right. First of all you must set up the option for nccheck_type in your config.pro
then Machining > NC Sequence > select a Sequence >Play Path > NC Check
Also your Workpiece must be visible.
I hope this help you. Zdenek
Edited by: kuncar
