Pro/ENGINEER Basic Terminology
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Pro/ENGINEER is:
Feature-based -- Pro/E builds the model one feature at a time. A feature is the smallest building block in a model. Building your model with simple features makes your part more flexible.
Associative -- Changing the design at any level will automatically change the design at all levels. For instance, you can change a dimension in a drawing, and the resulting change will be reflected in the part and assemblies instantly.
Parametric -- Features of the model are interrelated. Modifications of a single feature propagates changes in other features as well, preserving your design intent. A relationship between features develops when one feature references another and is known as a parent/child relationship.
