Pro/E WF2.0 Unix Installation Help
  • Thread starter Thread starter caddoktor
  • Start date Start date
C
caddoktor
Guest
Hi there,
I installed yesterday Pro/E wf 2.0 on sun solaris sunblade 1500 as root.
Pro/E launches fine with no problem but if I login as user it does not launch ProE
I have copied and paste the error message please advice what am I missing here.
usr-u01:/home/usr1>proe1
License request failed for feature PROE_ReviewPlot: -92:
feature removed during lmreread, or wrong SERVER line hostid
I really appreciate your help.
Lucas
Check the permisions of the startup folder, as well in the startup folder for Pro/ENGINEER there should be a std.out file, if you look in there it could contain more errors. My first guess is startup directory permission. The license request looks like a bad entry in license file,so the otheridea is that your looking at an old path or license so check the launch command.
