Pro-E to Vericut Interface
  • Thread starter Thread starter gold-cam@dlc.fi
  • Start date Start date
Did you change proev.bat file in <Load Pro/E point>\bin directory?
I add next rows:
REM Addition TO the script by XXX 27.09.2011
REM set VERICUT_FEATURE_NAME=Embedded
set VERICUT_FEATURE_NAME=CGTECH_LICENSE
call T:\cgtech\7.1.5\windows\commands\vericut.bat %1 %2 %3 %4 %5 %6 %7 %8 %9
goto end_cgtech
REM ********* END ADDITION*****************
Hello, Thanks for reply. I am not so familiar with vericut.bat. I tried to add the lines but it does not help. Which is the right locations for lines? All what I can see with the Vericut Interface is Files And Operation names. I can not Generate Files or Run Vericut. If open Vericut alone I get message below , but it still opens.
