Pro/E to DXF export
  • Thread starter Thread starter MaDI
  • Start date Start date
M
MaDI
Guest
how to setup the length of line segment of hidden line (PHANTOM) after exporting drawing to dwg or dxf file.
Now after exporting and opening drawing in Autocad hidden line looks like
but I want something like this
Thx.
Before you export the *.dwg or *.dxf file,you should change the diaplaymode of drawing__hidden line.
I'm a chinese, so my English was bad.
I think you can set up the config about export_dxf_layer to part*, I forget. you can test .then you can modify the style in the autocad layer to your wanted style.
