Ohh sorry, Its not related to family table .Its to pattern table option. I think I have confused you, any way thank you for the reply..
Pl ref the image, the green part is PCB, white is LED, deep gray is micro switch and brown is front cover. Now i have assembled led in PCB & patterned using direction option (pitch 25.5mm & 8 Nos) and in the same manner micro switch also (pitch 25.5mm & 8nos). In front cover I have cut the hole and patterned using direction option (pitch 25.5 & 8nos). PCB, LED and switch is a single assembly and front cover is a separate part. Now after assembling this there is no link between LED location and front cover hole as well switch and front cover. If I change the position of LED the hole should automatically locate in the line of LED.
To achieve this I know to used Copy geometry. Since the pitch between led , switch and hole in front cover is same (pitch 25.5 & 8nos) I want to try it with pattern table option.
Once I do pattern using table option for LED, can i call the same table to pattern the switch as well to make hole . so if i change the pitch of led pattern table automatically it will be updated in switch pattern table and hole pattern table, so it becomes parametric.
At last my doubt is if i create a pattern table for LED, can i use the same pattern table to pattern the switch and hole???
Hope you understand my doubt
Sister thank you for reading this big story
Warm regards - Prabhu
