pro-e convert to pdf problem.
  • Thread starter Thread starter boopathi
  • Start date Start date
B
boopathi
Guest
Hi, friends
i am using pro e wf3 in and in that i
have a problem while printing in to pdf. if i use true type font every
thing is coming correct but the tolerance are not printing correctly. it
is printing like the upper tolerance is printing in small size and
lower tolerance is printing in large size font. If i use stroke all font
the + & - sine are look like same and text also not clear. i used
all the font in my system. pl some one help........
Boopathiraj
Why use TT fonte? The drawing and pdf files are getting
bigger filesize.
Yiu can also notice that ProE are getting slow in working
with drawings if you have a lot of text.
I agree, I'd use the default font on the drawing. If you need a TTF, you can get that when you create the pdf without changing the font on the drawing. Or you can turn it off by selecting the option "Stroke all fonts".
I downloaded a free program called Bullzip and then print to PDF, it gets round that problem.
CutePDF is a freebie that works very well.
So is the pdf utility, doPDF. It's also a freebee that works quite well.
Bob
