J
jzemsky
Guest
If you use drawings or layouts that were copied (duplicate objects, save as, etc.) and are using Pro/E 2002030+ and Intralink 3.1 (maybe 3.0, but I have not confirmed) you will get Ghost Objects. These Ghosts will not be removable by any normal method.
Stay at Pro/E 2001440 to be safe.
PTC has said that the build after 2002140 will fix this.
If you have this problem let me know and I will send you a tip sheet on fixing these.
z
z
