Pro/2001 crash when using sketcher replace function
  • Thread starter Thread starter cschuette
  • Start date Start date
C
cschuette
Guest
Hey all,
I'm working with Pro/2001 Build 2002140...I am trying to edit a sketched curve using the replace function in sketcher mode, the only object referencing this curve is a style feature (surface created from 4 boundary curves). When I sketch in the new geometry, select it, hit replace, then select the old sketcher geometry my Pro session bombs out completely. I'm working on a Dell P1130 1.8GHz, 1GB RAM with a 64 MB 3Dlabs Wildcat II 5110 vid card. Has anyone else ever run into a similar crash? I'm wondering if this might just be a bug in this particular build? Any help or suggestions would be appreciated. Thanks!
