Printing to UserForm
srgoodall
I'm trying to print to a user form. VB ref book indicates format as:
UserForm1.Print (data,strings etc to print)
is all that's needed. However, I get an error stating that property is not supported.
Any suggestions? thanks
Do you want to print TO a form or FROM a form?
The following will print FROM a form
Code:
UserForm1.PrintForm
Hi srgoodall,
That used to work for me, but now I usually just set a label or textbox and either change the labels caption or the textbox's contents.
HTH
Todd
HTH, thanks. I'd like to print directly without using labels/textboxes because the number of entries is unknown and tabs, carriage rtns can be more easily controlled. thanks again.
srgoodall
