Sounds to me like you have an B-Size SE drawing and want to print it out on two A-Size pieces of paper that you can tape together to make a full-size drawing.
If that's the case, read on, otherwise ignore.
On your Solid Edge draft, change keep your B-Size templates and drawings views as is. In the drawing sheet setup, change the page size to A.
Move your entire drawing (border, views, dimensions, notes, etc.) to the lower left corner is aligned with the lower left corner of the page.
Print 1:1.
Move your entire drawing to the lower right corner.
Print 1:1.
The first print job will truncate the right side of the your drawing and the second print job will truncate the left side. Put them together, and you get a full drawing will little to no overlap. Of course you still have to deal with page margins unless you have a (photo) printer that can print to the edge of a page.
--Scott
