Yes you can,
I am assuming your talking V4 catia.
just tried it a few days ago.
not at work now, so here is what I remember.
im not a computer sys person here, but try my best to figure this stuff out.
you will need to set up another plotter config file.
then once in catia you select this new plotter and it
will send it to the specified file.
The plotter config files are text files.
I believe that your plotter config files are in your home/catadm/adm/pltcfg. there may be several different locations for these plotter config files due to multiple
environments.
I took our plotter config file for our normal plotter, made a new copy of this file and edited it slightly.
such lines as
*name HPGL2
*EXPORT HPGL2 (HPGL didn't work for me)
then looked at the tif plotter file configuration and copied someof that near the bottom where it outputs to a file, instead of sending it to the plotter.
changed the catout.tif to catout.hpgl2
delete or comment out the line where it would send it to the plotter. this would be a lpr line of somesort.
the info for the tif is posted in this forum.
thread560-31352
