Prevent Deletion with Knowledgeware?
solid7
1,403
I have some geometry that is part of a "Smart part", that needs to be prevented from being deleted, even when not used. (at a given moment)
Is it possible to either use a Knowledgeware rule to prevent deletion, or a reaction to undo the deletion, after the fact?
Thank you.
hmmm...
add a list with all element you want to keep
have a action run if the count of the list change (not sure this part will work)
the run will just undo
Eric N.
