I'm a structural engineering contractor on assignment at an oil refinery, working with piping designers and process engineers. The objective is to design and implement pressure-relief safety valves for heat exchangers. The valves are often located on or near existing platforms for accessibility. Often the available platforms are attached to, and supported by the sidewall of a (vertical steel cylinder) pressure vessel. I'm hoping to find a reliable and conservative, (and hopefully simple), way to analyze the vessel's sidewall. The platforms are typically supported by cantilevered steel beams. Therefore the moment would often the controlling factor for loading. The new loads introduced for the safety valve, block valve, and piping usually are located at the cantilevered end, so moments are increased dramatically. My boss typically refers this analysis, when needed, to an available mechanical engineer; but getting the results is like pulling teeth! Any tips, tricks, or rules of thumb for this type of analysis would be appreciated. Thanks.
Pete, P.E.
Pete, P.E.
