Hi karvin (Mechanical), mixsist (Electrical), VPL (Nuclear)
Houston, Texas AREA the best is South Texas Section ASME:
Pressure Vessels: ASME SECTION VIII, DIV 1, DIV 2, DIV 3.
Piping: B31.1, B31.3, B31.4, B31.8
REFERENCE NOTE'S: PAST SEMINAR NOTEBOOKS AVAILABLE
Available at $75.00 per set are:
1994 ASME B31.3 Piping Code Seminar
2001 Piping Design & Pipe Stress Analysis Seminar
2001 Pressure Vessel Seminar - Sec. VIII - Div. 1, 2, 3
Order your seminar notebook from KATHY SMITH at 713-523-4565 or FAX 713-523-6767
and send your check along with your request for the set(s) that you need to
South Texas Section ASME at P.O. Box 25045, Houston, Texas 77265.
REGARDS Upcoming training dates:
January 21, 2003 - COMPRESS
January 22/23/24, 2003 - FEPipe
TO FE-PIPE traning :
New All Pro is now available. It includes two very powerful and easy to use programs for analyzing appurtenances on shells (e.g., nozzles, lugs) and flanges by FEA.
REGARDS TO BOS FLUIDS traning:
REGARDS TO HEAT EXCHANGER traning:
COMPRESS Build 6198 includes the A02 Addenda of the 2001 Code Edition, optional TEMA and ASME Exchanger modules, new Vessel Wizard, and new Flange Wizard. Read more about it here
Regards to HEAT EXCHANGER TRAINING:
• Heat Transfer Research, Inc. (HTRI): To advance heat transfer and fluid flow technology for our customers by conducting research, developing practical methods and computational tools, and providing related services.
New Letter
Leonard@thill.biz
