pressure vessel boxes
mielke
181
Can anyone refer me to what codes refer to the design (wall thickness in paticular) of a pressurized rectangular box. I have been told that Section 8 div 1 deels only with cylindrical or spherical vessels.
See Appendix 13 of the Section VIII, Div.1 code. It deals with vessels with noncircular cross sections.
i do not have any asme material (and would prefer not to spend $600+) does anyone know if this appendix would help in designing a pressurized rectangular box?
Also since i prefer not to spend the money can anyone refer me to an alternate way of calculating what i need? i have found plenty of stuff in calculating cylindrical object but nothing for thickness of a box.
mielke, try a site search, this subject has been discussed before, I seem to remember a paper on the topic.
However, before constructing any sort of pressure vessel, you should determine if a Coded vessel is required for liability, contractural or other reasons.
Mike
mielke (Mechanical)
SOLUTIONS 1
Google search for
Non-Circular Pressure Vessels-Some guildance notes for designers M. Starczwksi B.Sc. Eng. Stress Engineer, Research Dept, British Enginer Technical report 1981 Volume XIV.
SOLUTIONS 2
SOLUTIONS TO DESIGN OF WELDMENTS
The James E. Lincoln Arc Welding Foundation, Cleveland, Ohio
Been their did that
Leonard Stephen Thill
Have a read of this about Appendix 13 to see if it applies for you. If it does, I suggest you do a cost comparison of how much it will cost you to find some free alternative somewhere etc. or $660 which will get you a result in a few hours of reading and banging calculations on a writing pad.
We use appendix 13 to design heat exchangers, spefically the rectangular steelwork around a graphite block.
As far as we are aware it is the only code that covers rectangular vessels.
