pressure variation
sudershanm
we had a doubt about the given data as suction pressure is 59 meteres above the mean sea level..? if we calculate this with p=qgh it is not matching..and one thing is as the altitutde increses gradually the pressure has to decrease but if we apply the same formula how will it match ...?
It should match provided you take correct density, acc. due to gravity and height of air column. But you have a simple formula to check atmospheric pressure roughly.
P = 29.92 - 0.001H where P = atmospheric pressure in inches of Hg, and H = height of the area from MSL in feet.
So for 59 meters it is 29.92 - (0.001 x 59 x 3.28)= 29.72 inches of Hg. (or 755 mm of Hg)
Check this with your barometer.
sudershanm, what are you talking about? It seems like there's about two paragraphs worth of explaining missing...
Her is a quick way of figuring out pressures in feet of water which you can easily convert to metric.
14.69psi*144 sqin/sqft/ 62.4 lbs/cu.ft= 33.9 feet of water or 406.8 inches of water. Therefore you have
27.69 inches of water per psi.
You can do the conversion!!!
