Hello, this is not usually my problem to deal with but it is at the moment.
I'm dealing with a with a water well and a predesigned elevated storage tank by requirements of the project. I also have to meet minimum storage requirements and static and residual pressures. For this reason I will also require an at grade pressure storage tank to meet minimum storage requirements and a booster pump system to meet minimum pressures.
My plan was to have the well pump up to the elevated storage tank which would then gravity feed to fill the at grade tank and the water system until all aspects were filled and the float switch in the elevated tank shut off the well pump.
Since I have little practice at this the pressure tank is baffling me. At first I assumed there would be something similar to an air release valve on a water main installed on the tank so that it could fill completely with water and dispell the air pocket. Would this cause the booster pump to collapse the at grade tank when it kicked on?
So do you just live with pressurized air in the at grade tank due to the head of the elevated tank?
How do you tell how much of your at grade tank is full at static to be sure that you meet storage requirements?
Sorry if there is a simple answer I'm overlooking but I've been out of school a bit and this isn't what I'm normally used to doing.
Any advice is welcome.
