sjohns4
- Sep 14, 2006
- 123
At the local WTP they are having a surge problem from one of the high service pumps. The pump is a 1600 GPM pump with a swing check and soft start drive. The other two pumps are 2400 GPM pumps with soft starts and electric check valves. The problem seems to be that the pump ramps to full speed before the check even opens, and when it does the pressure spikes from ~110 psi to +160 psi. The drive is an Allen-Bradley SMC flex and according to the tech support folks it doesnt matter what the ramp time is set to, the drive will ramp the motor to full speed as soon it can, which should be easy to do when the pump isnt moving water. We tried to current limit the motor from the drive. When it was set at 200% FLA the motor quickly ramped up to partial speed but when the contacts closed at the end of the set ramp time it jumped to full speed. I changed the current limit to 300% and it ramped up as it always did - with the surge pressure when the check opened. I think ideally what the drive needs to do is quickly ramp to a speed maybe 70%-80% of full speed and slowly ramp up to 100%, but the tech support folks say it wont do that.
Does anyone have any suggustions as to what we can do to fix the surge problem without replacing the drive or installing an electric check valve?
Also, there is a surge relif on the high service line leaving the WTP, if it's working shouldnt this prevent surges from entering the system due to a quick pump start?
Thanks,
Mike
Thanks,
Mike
