i'd imagine that some load-cells might do what you want--what kind of resolution are you looking for? are you looking for max load per cycle or the time-varying dynamic load? if just max load, a pressure sensitive film would probably work--but if looking for detailed information on the dynamic loading of different areas of the sole, then you probably will need something much more complex.
