GregDesign asked:
"so if you have elbows and tees in you piping system, does pressure increase or flow decrease? Confusing."
If you think seriously about that question and there is an infinitely powerful prime mover driving a 100% efficient Fixed Volume Pump at a constant RPM supplying the circuit at 10 GPM with no other possible flow path except the "piping System" it is obvious that pressure will have to increase to overcome the resistance since flow cannot decrease with this example scenario.
Pumps produce Flow and only flow. Resist that flow and pressure increases. So does the pump make the pressure increase or does the Resistance to the pumps flow make that increase.
I've seen grown men argue that one all day about like arguing which came first, "The Chicken or the Egg?"
Set up your own experiment with a pump driven by an electric motor that has a Pressure Gauge, Flow Meter, a Relief Valve and a Ball Valve, in that order, all rated for the pressure you desire on its Outlet Port. Connect the Inlet line of that pump to a tank and the Outlet from the Ball Valve back to the same tank.
Now, with the Ball Valve fully open turn the electric motor on and check pressure and flow. It should read almost no pressure since resistance is extremely low, if all the components are rated at the flow you chose, and full pump flow. You can run this circuit as long as you want and pressure will never increase UNLESS you start RESISTING THAT FLOW by closing the Ball Valve. In fact you can set pressure at any level by the amount of restriction you set with the Ball Valve up to but not exceeding the Relief valve setting.
Many pumps have been changed unnecessarily when a pressure gauge reads at or near Zero when the problem actually was an unrestricted flow path to tank was wide open. That is why I always spesify a Flow Meter at the pump outlet, before the relief valve, on any circuit I design.
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING
