199292
- Nov 17, 2004
- 5
It has been a while since I have had to interpret the results from a hydrant flow test using a pitot tube. For example I have the results of the static pressure to be 110 psi and the residual to be 75 psi. From this I assume I plug these numbers into the V=[2((110-75)*144)]/62.4 in order to get the velocity and from that number I should be able to get the flow through the steamer nozzle. Is the diameter of the steamer nozzle usually 5.25"? With this scenario I get a flow rate of 846 gallons per minute. Next question, should I be able to find the pressure in the pipe in the vicinity of that particular hydrant for any flow rate. For example could I calculate what the pressure is if I have 735 gallons per minute flowing through it using the reults of my flow test manipulating the equation from above. I would like to then plug this number, the pressure number, into Bernoulli's eqaution to find if the pipe I am designing would meet certain flow and pressure requirements down stream. Some guidance would be appreciated.
