we are planning to do some test to see the high temperature performance of a device. To do it, we need to fill an small aluminum tube (ID 2.5", 25" long) with olive oil to about half of its volume, and then put the tube in oven to heat it up to 330 degree fahrenheit. The tube is sealed with oring.
We know the expansion of this oil will about 10%. Olive oil has boiling temp 570F, smoke point 470F. The question is
1. How high the pressure will build up in the tube at 330F?
2. We certainly do not want any smoke (or fire!) since it will ruin the oven (expensive one!). Any issue you see with the plan?
Thanks!
Thanks!
