mielke
- Aug 24, 2009
- 181
I want to make sure that i am interpretting equations right. The equation for pressure drop across bare tube banks has (pi/po-1) in it for the effects of the change in density. (pi is inlet density, po is outlet density)
Now if pi is greater than po (ie the fluid is being heated) than we have a positive pressure drop. but if pi is less than po than we get a negative term in the equation.
So does this mean if we have a fluid on the outside of a bare tube bank it will lose pressure due to frictional resistance of tube bank but gain pressure due to temperature change (due to change of density).
