I am designing a sample cooler. The sample stream will come from discharge PG of the pump and run back to the pump suction.
Since the deltaP is large, the flow will be large as well.
We are going to use a globe valve to control the flow.
How can I determine the flow so there will be enough pressure for the stream to go back into pump suction.
DeltaP=1400KPa. Pipelenght=15 m
Approximate deltaP for the cooler=200Kpa
Any help appreciated
