You need to look at the system to calculate the pressure drop across a control valve.
Take an easy example, letting down steam from 200 psig to 50 psig. If the piping is short, then the pressure drop is always going to be 150 psi regardless of the flow rate (for this purpose, I'm ignoring variations in the upstream or downstream steam pressure).
Another example could be pumping product from a unit to storage. The destination pressure will vary depending on the level in the storage tank. The line losses through piping and equipment will set the outlet pressure on your control valve. For the maximum outlet pressure I would typically use the max flow and resulting pressure drop through the equipment/piping and a full tank. For the minimum outlet pressure I would then use the turndown flow and resulting pressure drop at say a close to empty tank. If this is a new design, then you need to decide how much pressure you want to take across the pressure drop at the maximum flow case. I find this approach gives me a good estimate of the maximum sizing case, normal sizing case and minimum sizing case. The maximum and minimum sizing cases are the most important, if you define those correctly for your instrument engineer the selected valve will handle any intermediate case which will include the 'normal' case.
