API 674 definition of Pressure-containing parts and the pressure-retaining parts:
Clause 1.4.1 7 A pressure-containing part is a part that acts as a barrier between processo r motive fluid and thea tmosphere. Such parts include, but are not necessarily limited to the liquid cylinder, the discharge manifold, the suction manifold, the stuffing box, cylinder plugs and covers (when in contact with process fluid), valve seats (when a portion is in contact with the atmosphere), the gas cylinder, the gas cylinder head, the valve chest, and the valve chest cover and heads.
Clause 1.4.1 8 A pressure-retaining part is a part whose failure
would allow process or motive fluid to escape to the atmosphere. In addition to the pressure-containing parts listed in 1.4.17, pressure-retaining parts include, but are not necessarily limited to, liquid and gas cylinder bolting, stuffing box bolting, gland bolting, glands, and covers that constrain plugs and valve stops. Not included in pressure-retaining parts are parts such as packing, gaskets, pistons, plungers, piston rings, rods, valves, seats (when completely surroundbeyd pressurecontaining
parts), and internal bolting.
Does anyone have an ASME reference for the above definitions, having just hit the wall with a fabricator refusing to accept this definition not sourced from the Code, but a standard only...
gr2vessels
