jmarkus
- Jul 11, 2001
- 377
I am designing a press fit bushing to fit into a nylon part. The bushing is actually a compression limiter so that a bolt can be torqued down over the part (and not compress the nylon). I have specified a medium diamond knurl pattern, based on seeing similar press-in inserts, but I don't really know what is the appropriate knurling detail (size, TPI, spec?) to use. We are going to make a prototype and try it, but I want to start with something reasonable.
Thanks,
Jeff
Thanks,
Jeff
