jives
- Oct 26, 2005
- 12
I have a question on bolt pre-load for an ASME B31.1 Code pipe flange joint.
Should the total load on a bolt in the joint, including applied load from pipe internal pressure and pre-load, NOT exeed the allowable stress of the bolt material at temperature ? Or can total bolt load be safely brought up to 50% of Yield strength.
Also, what is the recommended joint safety factor (ie: ratio of pre-load to applied load), to make for a leak-free joint ?
Anybody out there have experience with this ?
Jonathan Ives
Project Engineer
Transalta, Alberta Thermal Plants
Duffield, Alberta
Jonathan Ives
Project Engineer
Duffield, Alberta
