jonasinc
Materials
- Feb 17, 2005
- 23
Does anyone have experience with preinsulated piping installed underground in a wet environment (high water table)? What materials are recommended for the insulation, conduit and outer shell?
Have you experienced ID corrosion of the steel conduit due to water ingress into the insulated annulus around the carrier pipe?
If so, what were the sources of the water ingress?
