Preheat temperature of A335-P5 1
DBreyer
Materials
May 16, 2014
62
Hello all,
in our company's internal standard until now a preheat temperature of 300°C for welding P5 piping is required.
Now a disucssion is started weather a temperature range of 250-300°C is also acceptable.
In every case PWHT is required so I don't worry over much about remaining martensite.
Also Asme B31.3 requires an even lower preheat temperature.
Does anybody know of a standard (api, nace,..) requiring at least 300°C preheat temperature?
Pipes are used in corrosive (mainly sulfidation) refinery service.
Thank you for your advice.
Daniel Breyer
Inspection Engineer
For SA 335 P5 alloy steel, a proper minimum preheat temperature is 200-220 deg C. Having a preheat of 300 deg C is of little benefit and places you up against the interpass temperature limit. What was the basis for my recommendation? - ASME B31.1 for P-No 5B materials, which is conservative.
