ot110
- Jun 19, 2011
- 2
I've recently run a few experiments to investigate the impact on changes in moisture content and dry density on the saturated preconsolidation pressure, and am a little confused on to how to conclude.
The test run were on a clayey silt, first compacted using the standard proctor method, then saturated and consolidated in a triaxial cell using an isotropic pressure ramp up to 1500kPa. Several problems came up during testing which meant I could only test 4 samples of moisture contents between 15.8% and 16.8% (optimum = 16.4%) and dry densities between 1.74 and 1.77 g/cm³. The resulting graphs plotted against preconsolidation pressure show a scatter of points, but i havent found any real way of going about forming any relationship between them, if one even exists.
Does anyone have any tips on what i should be looking for, or what theoretical existence should exist? I was under the impression that with lower moisture contents, and higher dry density, the preconsolidation pressure should increase.
Please reply a.s.a.p, I need to submit my findings tomorrow at midday.
Many thanks
Many thanks
